# Item & Things
Items and Things are the major entities of openHAB (opens new window) to control and monitor the home. These can be accessed via the "Items & Things" section of the Blockly Toolbox.
items-and-things
# Item and Thing Blocks
blockly-item-thing
blockly-item-example
See a video introduction at youtube Working with Items (opens new window)
# Item
blockly-item
never use this block alone as it only returns the items name which alone does not make sense. Instead use the get-Item-Block below.
  • Clicking 'MyItem' displays a list of Items to pick from
  • Technically this block returns the name of the item as a String.
  • As a result, this block can be used wherever the item name is required as a String.
  • Learn more about items here (opens new window)
# Get Item
getItem
  • Clicking 'MyItem' displays a list of Items to pick from.
  • Technically this block returns an item object, to be used to retrieve specific attributes using other blocks (see below).
  • In openHAB3 this block does not return a String, so it cannot be directly attached to a log-block, as demonstrated below.
    • Tip: Often you do want to retrieve the state, hence use the "Get State of Item"-block below
    • The block returns the item itself.
logging-getItem
blockly-getItemStateDoesntFit
# Get State of Item
blockly-getStateOfItem
it is recommended in this case to assign this to a variable and use the "String-Append-Text" with an empty "" to convert it into a String for further processing.
See the Item-State documentation (opens new window) for more information
# Get Members of Group
blockly-getMembers
  • returns a collection of items which should be used with a for-each-block to loop over the items
  • it can be attached to a log-block which would list all items in that block in the form a string representation as follows
Hint: Make sure you are using typed variables!
  • Alternatively you can use the item block var the loop variable to send a command to the items of the group
blockly-getMembersExample
# Get Items with Tag
blockly-getMembers
Function: Gets all items with the given tags which you can iterate over via a loop
  • returns a collection of items which have the given tags
  • multiple tags can be provided which then need to be separated with a comma
  • if multiple tags are given, the item must have all of the tags ("and"-condition)
If you need an item that has one of multiple tags, then you need to use one block of each and then use the "concatenate list block" (opens new window) to combine the results.
# Get particular attributes of an Item
blockly-getItemAttributes
It requires an item object to be connected.
  • name: String
  • label: String
  • state: State
  • numeric state: Number
  • quantity state: Quantity
  • previous state: State
  • previous numeric state: Number
  • previous quantity state: Quantity
  • last state update: ZonedDateTime
  • last state change: ZonedDateTime
  • category: String
  • tags: Array, e.g.
[plannedTimes]
  • groups: Array, e.g.
[plannedTimes, timers]
  • type: String
blockly-getItemAttributes-fix
Simplified usage
Since openHAB 4.1 an optimization was introduced that simplifies the usage:
It allows to attach the item block directly instead of having to use the intermediate getItem-Block. Internally Blockly detects the added type and applies the right code generation.
Use typed variables:
Due to the fact that Blockly provides untyped variables it is then not able to detect the type of the value that has been assigned to a variable which may result into unexpected behaviour. Therefore, always use a typed variable instead
Special handling for Arrays
  • they cannot be connected to a block that expects a String (e.g. log-block)
  • they must be handled using a for-loop as follows
blockly-specialArrayHandling
# Send Command
blockly-sendCommand
  • value: any state value that is allowed for that item, eg. ON or OFF for a switch.
  • Clicking 'MyItem' displays a list of Items to pick one item from
For the difference between send command and post update see "Manipulating States" (opens new window) and "Event Bus Actions" (opens new window).
More about that topic can be viewed at youtube Sending Commands (opens new window)
Item-block examples
Example 1:
  • Check if MainSwitch is ON.
  • If ON, send ON command to livingroomLight item.
blockly-sendCommandExample1
Example 2:
  • Get the state of MainSwitch and
  • Immediately send it as a command to F2_Office_Main_Light
blockly-sendCommandExample2 Ensure that the receiving item can handle the state of the 'sending' item.
# Item Metadata
The metadata blocks provide an easy way of accessing namespace metadata information both for reading and writing. Accessing config metadata on hierarchical levels as well as variable support that allows iteration over computed names is supported (see the examples below).
Note: Metadata blocks are not available for Nashorn but only for GraalJS / JS Scripting.
Here is an expire metadata definition which is visualized as
metadata-expire
and modelled in YAML as
value: 0h3m0s
  ignoreStateUpdates: "true"
  ignoreCommands: "true"
with the blocks that can access it:
![blockly-metadata](../images/blockly/blockly-metadata.png)
There a two different type of blocks:
The value block is the main one for the _value_ of the namespace, which is also directly shown in the MainUI's list of an item's metadata, while the _config_ part holds more complex configuration of that metadata structure below the entry _config_.
The following blocks allow to _change_ the config values in the namespace _expire_:
![blockly-metadata-change](../images/blockly/blockly-metadata-change.png)
Here is a definition of a more complex metadata namespace:
```yaml
value: ON
  ooone: "123"
  oone:
    two: "456"
  one:
    two:
      three: "756"
  field1: 1
  field2: 2
  field3: 3
which allows deep hierarchy property access via a configkey-dot-notation like one.two.three
Using variables and loops properties like field1, field2, field3 can even be accessed in a computed way:
# Thing
blockly-thing
  • To be specific this only provides a thing picker that provides the ID of that thing (and not the thing object itself that holds several properties)
  • Clicking 'MyThing' displays a list of Things to pick from
  • Technically this block returns the thingUid of the thing as a String
  • Learn more about things (opens new window) or thing-concepts (opens new window)
blockly-thingExample
will write the following ID of the thing into the log
# Get Thing
blockly-thing
Function: Gets a Thing for use in other thing related functions
  • Clicking 'MyThing' displays a list of Things to pick from.
  • Technically this block returns a thing object, to be used to retrieve specific attributes using other blocks (see below).
# Get Thing Status
blockly-getThingStatus Function: Gets the Thing Status
  • Technically this block returns a ThingStatus (opens new window) - a String with one of the following statuses
    • UNINITIALIZED
    • INITIALIZING
    • UNKNOWN
    • ONLINE
    • OFFLINE
    • REMOVING
    • REMOVED
# Get particular attributes of a Thing
blockly-getThingAttributes
Function: Get particular attributes of a Thing
It requires a thing object to be connected.
  • UID (unique Thing ID): String
  • label: String
  • status (like ONLINE/OFFLINE): String
  • status info (status plus further info like "light not reachable"): String
  • thing type UID (unique ID of the Thing type): String
  • bridge UID (unique ID of the Bridge): String
# Get Things
Function: Gets all things and returns a list of Thing-Objects.
blockly-getThings
The following loop iterates over all things and logs out the status. Note that it uses a typed variable for that.
blockly-thingsLoop
