# MEATER Binding
This is an openHAB binding for the MEATER probe, MEATER® is a trademark of Apption Labs™ Limited. A Traeger Company.
This binding uses the MEATER Cloud REST API.
meaterapi: Bridge - Communicates with the MEATER Cloud REST API.
meaterprobe: The MEATER probe - Only support for cloud connected MEATER probes (MEATER Block and MEATER Plus)
The binding supports auto-discovery of all MEATER probes belonging to the configured cloud API account.
NOTE: For The Original MEATER and MEATER Plus you need to have your MEATER app running and the MEATER probe(s) must connected to the cloud (out of the charger box) before you start the discovery.
After the configuration of the Bridge, you need to perform a manual scan and then your MEATER probe(s) will be automatically discovered and placed as a thing(s) in the inbox.
When manually configuring the probes, the console command openhab:meater showIds can be used to identify the IDs of all connected probes.
Since the probes are unnamed, they can be hard to identify.
For this reason, the ambient temperature is included in the list.
This might help isolating an individual probe.
# Supported Things and Channels
# MEATER Bridge
# Configuration Options
| Parameter | Description | Type | Default | Required |
| The email used to login to your MEATER Cloud account | String | NA | yes | |
| password | The password used to login to your MEATER Cloud account | String | NA | yes |
| refresh | Specifies the refresh interval in seconds | Number | 30 | no |
The following channels are supported:
| status | String | Can be used to trigger an instant refresh by sending a REFRESH command. |
# MEATER Probe
| deviceId | Unique id for your MEATER Probe | String | NA | yes |
| internalTemperature | Number:Temperature | Internal temperature reading of MEATER probe |
| ambientTemperature | Number:Temperature | Ambient temperature reading of MEATER probe. If ambient is less than internal, ambient will equal internal |
| cookTargetTemperature | Number:Temperature | Target temperature of current cook |
| cookPeakTemperature | Number:Temperature | Peak temperature of current cook |
| lastConnection | DateTime | Date and time of last probe connection |
| cookId | String | Unique cook ID of current cook |
| cookName | String | Name of selected meat or user given custom name |
| cookState | String | One of Not Started, Configured, Started, Ready For Resting, Resting, Slightly Underdone, Finished, Slightly Overdone, OVERCOOK! |
| cookElapsedTime | Number:Time | Time since the start of cook in seconds. Default: 0 |
| cookRemainingTime | Number:Time | Remaining time in seconds or UNDEF when unknown. |
| cookEstimatedEndTime | DateTime | Date and time of estimated end time for current cook |
# Example
# Things-file
Bridge meater:meaterapi:block "MEATER Block" [email="", password="", refresh=30] {
meaterprobe probe1 "Meater Probe 1" [deviceId=""]
meaterprobe probe2 "Meater Probe 2" [deviceId=""]
meaterprobe probe3 "Meater Probe 3" [deviceId=""]
meaterprobe probe4 "Meater Probe 4" [deviceId=""]
# Items-file
Number:Temperature Probe1InternalTemperature {channel="meater:meaterprobe:block:probe1:internalTemperature"}
Number:Temperature Probe1AmbientTemperature {channel="meater:meaterprobe:block:probe1:ambientTemperature"}
String Probe1CookId {channel="meater:meaterprobe:block:probe1:cookId"}
String Probe1CookName {channel="meater:meaterprobe:block:probe1:cookName"}
String Probe1CookState {channel="meater:meaterprobe:block:probe1:cookState"}
Number:Temperature Probe1CookTargetTemperature {channel="meater:meaterprobe:block:probe1:cookTargetTemperature"}
Number:Temperature Probe1CookPeakTemperature {channel="meater:meaterprobe:block:probe1:cookPeakTemperature"}
Number:Time Probe1CookElapsedTime {channel="meater:meaterprobe:block:probe1:cookElapsedTime"}
Number:Time Probe1CookRemainingTime {channel="meater:meaterprobe:block:probe1:cookRemainingTime"}
DateTime Probe1CookEstimatedEndTime {channel="meater:meaterprobe:block:probe1:cookEstimatedEndTime"}
String Probe1Status {channel="meater:meaterprobe:block:probe1:status"}
DateTime Probe1LastConnection {channel="meater:meaterprobe:block:probe1:lastConnection"}
Number:Temperature Probe2InternalTemperature {channel="meater:meaterprobe:block:probe2:internalTemperature"}
Number:Temperature Probe2AmbientTemperature {channel="meater:meaterprobe:block:probe2:ambientTemperature"}
String Probe2CookId {channel="meater:meaterprobe:block:probe2:cookId"}
String Probe2CookName {channel="meater:meaterprobe:block:probe2:cookName"}
String Probe2CookState {channel="meater:meaterprobe:block:probe2:cookState"}
Number:Temperature Probe2CookTargetTemperature {channel="meater:meaterprobe:block:probe2:cookTargetTemperature"}
Number:Temperature Probe2CookPeakTemperature {channel="meater:meaterprobe:block:probe2:cookPeakTemperature"}
Number:Time Probe2CookElapsedTime {channel="meater:meaterprobe:block:probe2:cookElapsedTime"}
Number:Time Probe2CookRemainingTime {channel="meater:meaterprobe:block:probe2:cookRemainingTime"}
DateTime Probe2CookEstimatedEndTime {channel="meater:meaterprobe:block:probe2:cookEstimatedEndTime"}
String Probe2Status {channel="meater:meaterprobe:block:probe2:status"}
DateTime Probe2LastConnection {channel="meater:meaterprobe:block:probe2:lastConnection"}
Number:Temperature Probe3InternalTemperature {channel="meater:meaterprobe:block:probe3:internalTemperature"}
Number:Temperature Probe3AmbientTemperature {channel="meater:meaterprobe:block:probe3:ambientTemperature"}
String Probe3CookId {channel="meater:meaterprobe:block:probe3:cookId"}
String Probe3CookName {channel="meater:meaterprobe:block:probe3:cookName"}
String Probe3CookState {channel="meater:meaterprobe:block:probe3:cookState"}
Number:Temperature Probe3CookTargetTemperature {channel="meater:meaterprobe:block:probe3:cookTargetTemperature"}
Number:Temperature Probe3CookPeakTemperature {channel="meater:meaterprobe:block:probe3:cookPeakTemperature"}
Number:Time Probe3CookElapsedTime {channel="meater:meaterprobe:block:probe3:cookElapsedTime"}
Number:Time Probe3CookRemainingTime {channel="meater:meaterprobe:block:probe3:cookRemainingTime"}
DateTime Probe3CookEstimatedEndTime {channel="meater:meaterprobe:block:probe3:cookEstimatedEndTime"}
String Probe3Status {channel="meater:meaterprobe:block:probe3:status"}
DateTime Probe3LastConnection {channel="meater:meaterprobe:block:probe3:lastConnection"}
Number:Temperature Probe4InternalTemperature {channel="meater:meaterprobe:block:probe4:internalTemperature"}
Number:Temperature Probe4AmbientTemperature {channel="meater:meaterprobe:block:probe4:ambientTemperature"}
String Probe4CookId {channel="meater:meaterprobe:block:probe4:cookId"}
String Probe4CookName {channel="meater:meaterprobe:block:probe4:cookName"}
String Probe4CookState {channel="meater:meaterprobe:block:probe4:cookState"}
Number:Temperature Probe4CookTargetTemperature {channel="meater:meaterprobe:block:probe4:cookTargetTemperature"}
Number:Temperature Probe4CookPeakTemperature {channel="meater:meaterprobe:block:probe4:cookPeakTemperature"}
Number:Time Probe4CookElapsedTime {channel="meater:meaterprobe:block:probe4:cookElapsedTime"}
Number:Time Probe4CookRemainingTime {channel="meater:meaterprobe:block:probe4:cookRemainingTime"}
DateTime Probe4CookEstimatedEndTime {channel="meater:meaterprobe:block:probe4:cookEstimatedEndTime"}
String Probe4Status {channel="meater:meaterprobe:block:probe4:status"}
DateTime Probe4LastConnection {channel="meater:meaterprobe:block:probe4:lastConnection"}
