# LIFX Binding
LIFX E27
Device Type Thing Type
Original 1000 colorlight
Color 650 colorlight
Color 1000 colorlight
Color 1000 BR30 colorlight
LIFX A19 colorlight
LIFX A21 1600lm colorlight
LIFX BR30 colorlight
LIFX Candle colorlight
LIFX Ceiling 13x26" colorlight
LIFX Ceiling 15" colorlight
LIFX Downlight colorlight
LIFX GU10 colorlight
LIFX Mini Color colorlight
LIFX PAR38 colorlight
LIFX Round Spot colorlight
LIFX Round Path colorlight
LIFX Square Path colorlight
LIFX Clean colorhevlight
LIFX+ A19 colorirlight
LIFX+ BR30 colorirlight
LIFX Beam colormzlight
LIFX Neon colormzlight
LIFX Outdoor Neon colormzlight
LIFX Outdoor Permanent colormzlight
LIFX String colormzlight
LIFX Z colormzlight
LIFX Tile tilelight
White 800 (Low Voltage) whitelight
White 800 (High Voltage) whitelight
White 900 BR30 (Low Voltage) whitelight
LIFX Candle Warm to White whitelight
LIFX Filament whitelight
LIFX Mini Day and Dusk whitelight
LIFX Mini White whitelight
Thing Type On/Off Brightness Color Color Zone (Abs) Color Temperature (Abs) Color Temperature Zone HEV Cycle Infrared Tile Effects
colorlight X X X
colorhevlight X X X X
colorirlight X X X X
colormzlight X X X X X
tilelight X X X X X
whitelight X X X
Channel Type ID Item Type Description Thing Types
abstemperature Number:Temperature This channel supports adjusting the color temperature in Kelvin. colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight
abstemperaturezone Number:Temperature This channel supports adjusting the zone color temperature in Kelvin. colormzlight
brightness Dimmer This channel supports adjusting the brightness value. whitelight
color Color This channel supports full color control with hue, saturation and brightness values. colorlight, colorhevlight, colorirlight, colormzlight, tilelight
colorzone Color This channel supports full zone color control with hue, saturation and brightness values. colormzlight
effect String This channel represents a type of light effect (e.g. for tile light: off, morph, flame) tilelight
hevcycle Switch This channel supports starting and stopping the HEV clean cycle. colorhevlight
infrared Dimmer This channel supports adjusting the infrared value. Note: IR capable lights only activate their infrared LEDs when the brightness drops below a certain level. colorirlight
signalstrength Number This channel represents signal strength with values 0, 1, 2, 3 or 4; 0 being worst strength and 4 being best strength. colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight
temperature Dimmer This channel supports adjusting the color temperature from cold (0%) to warm (100%). colorlight, colorhevlight, colorirlight, colormzlight, tilelight, whitelight
temperaturezone Dimmer This channel supports adjusting the zone color temperature from cold (0%) to warm (100%). colormzlight
The color and brightness channels have a "Power On Brightness" configuration option that is used to determine the brightness when a light is switched on. When it is left empty, the brightness of a light remains unchanged when a light is switched on or off.
The color channels have a "Power On Color" configuration option that is used to determine the hue, saturation, brightness levels when a light is switched on. When it is left empty, the color of a light remains unchanged when a light is switched on or off. Configuration options contains 3 comma separated values, where first value is hue (0-360), second saturation (0-100) and third brightness (0-100). If both "Power on brightness" and "Power On Color" configuration options are defined, "Power on brightness" option overrides the brightness level defined on the "Power on color" configuration option.
The temperature channels have a "Power On Temperature" configuration option that is used to determine the color temperature when a light is switched on. When it is left empty, the color temperature of a light remains unchanged when a light is switched on or off.
MultiZone lights (colormzlight) have several channels (e.g. colorzone0, temperaturezone0, abstemperaturezone0, etc.) that allow for controlling specific zones of the light. Changing the color, temperature and abstemperature channels will update the states of all zones. The color, temperature and abstemperature channels of MultiZone lights always return the same state as colorzone0, temperaturezone0, abstemperaturezone0.
The hevcycle channels have an optional "HEV Cycle Duration" configuration option that can be used to override the cycle duration configured in the light.
LIFX Tile (tilelight) supports special tile effects: morph and flame. These effects are predefined to their appearance using LIFX application. Each effect has a separate speed configuration option.
The desk light is a LIFX Clean that has a colorhevlight thing type which supports color, temperature and hevcycle channels.
# demo.things Example
Thing lifx:colorhevlight:desk [ deviceId="D073D5A3A3A3" ] {
        Type hevcycle : hevcycle [ hevCycleDuration=3600 ]
# demo.items Example
// Living
Number:Temperature Living_Abs_Temperature "Living Room Lights Color Temperature [%d K]" { channel="lifx:colorlight:living:abstemperature" }
Number:Temperature Living2_Abs_Temperature "Living Room Lights Color Temperature [%d K]" { channel="lifx:colorlight:living2:abstemperature" }
// Desk
Color Desk_Color { channel="lifx:colorhevlight:desk:color" }
Dimmer Desk_Temperature { channel="lifx:colorhevlight:desk:temperature" }
Number:Temperature Desk_Abs_Temperature "Desk Lamp Color Temperature [%d K]" { channel="lifx:colorhevlight:desk:abstemperature" }
Switch Desk_HEV_Cycle { channel="lifx:colorhevlight:desk:hevcycle" }
// Porch
Number:Temperature Porch_Abs_Temperature "Porch Light Color Temperature [%d K]" { channel="lifx:colorirlight:porch:abstemperature" }
// Ceiling
Number:Temperature Ceiling_Abs_Temperature "Ceiling Light Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperature" }
Number:Temperature Ceiling_Abs_Temperature_Zone_0 "Ceiling Light 0 Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperaturezone0" }
Number:Temperature Ceiling_Abs_Temperature_Zone_15 "Ceiling Light 15 Color Temperature [%d K]" { channel="lifx:colormzlight:ceiling:abstemperaturezone15" }
// Kitchen
Number:Temperature Kitchen_Abs_Temperature "Kitchen Light Color Temperature [%d K]" { channel="lifx:whitelight:kitchen:abstemperature" }
# demo.sitemap Example
    Frame label="Living" {
        Switch item=Living_Color
        Slider item=Living_Color
        Colorpicker item=Living_Color
        Slider item=Living_Abs_Temperature
    Frame label="Living2" {
        Switch item=Living2_Toggle
        Slider item=Living2_Dimmer
        Slider item=Living2_Abs_Temperature
    Frame label="Desk" {
        Switch item=Desk_Color
        Slider item=Desk_Color
        Colorpicker item=Desk_Color
        Slider item=Desk_Temperature
        Slider item=Desk_Abs_Temperature
        Switch item=Desk_HEV_Cycle
    Frame label="Porch" {
        Switch item=Porch_Color
        Slider item=Porch_Color
        Colorpicker item=Porch_Color
        Slider item=Porch_Temperature
        Slider item=Porch_Abs_Temperature
        Slider item=Porch_Infrared
    Frame label="Ceiling" {
        Switch item=Ceiling_Color
        Slider item=Ceiling_Color
        Slider item=Ceiling_Abs_Temperature
        Slider item=Ceiling_Abs_Temperature_Zone_0
        Slider item=Ceiling_Abs_Temperature_Zone_15
    Frame label="Kitchen" {
        Switch item=Kitchen_Toggle
        Slider item=Kitchen_Abs_Temperature
