# Python Scripting
This add-on provides support for Python 3 that can be used as a scripting language within automation rules. It is based on GraalPy (opens new window) from the GraalVM project (opens new window).
Also included is openhab-python (opens new window), a Python library to support automation in openHAB. It provides convenient access to common core openHAB functions that make the full range of Java APIs easily accessible and usable.
# Creating Python Scripts
When this add-on is installed, you can select Python 3 as a scripting language when creating a script action within the rule editor of the UI.
Alternatively, you can create scripts in the automation/python configuration directory.
If you create an empty file called test.py, you will see a log line with information similar to:
... [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/openhab/conf/automation/python/test.py'
To enable debug logging, use the console logging (opens new window) commands to enable debug logging for the automation functionality:
log:set DEBUG org.openhab.automation.pythonscripting
# Scripting Basics
Lets start with a simple script
from openhab import rule
from openhab.triggers import GenericCronTrigger
@rule( triggers = [ GenericCronTrigger("*/5 * * * * ?") ] )
class Test:
def execute(self, module, input):
self.logger.info("Rule was triggered")
or another one, using the scope module
from openhab.triggers import ItemCommandTrigger
import scope
@rule( triggers = [ ItemCommandTrigger("Item1", scope.ON) ] )
class Test:
By default, the scope, Registry and logger is automatically imported for UI based rules
# PY Transformation
openHAB provides several data transformation services (opens new window) as well as the script transformations, that are available from the framework and need no additional installation. It allows transforming values using any of the available scripting languages, which means Python Scripting is supported as well. See the transformation docs (opens new window) for more general information on the usage of script transformations.
Use Python Scripting as script transformation by:
Creating a script in the
$OPENHAB_CONF/transformfolder with the.pyextension. The script should take one argumentinputand return a value that supportstoString()ornull:"String has " + str(len(input)) + " characters"or
def calc(input): if input is None: return 0 return "String has " + str(len(input)) + " characters" calc(input)Using
PY(<scriptname>.py):%sas Item state transformation.Passing parameters is also possible by using a URL like syntax:
PY(<scriptname>.py?arg=value). Parameters are injected into the script and can be referenced like variables.
Simple transformations can also be given as an inline script: PY(|...), e.g. PY(|"String has " + str(len(input)) + "characters").
It should start with the | character, quotes within the script may need to be escaped with a backslash \ when used with another quoted string as in text configurations.
By default, the scope, Registry and logger is automatically imported for PY Transformation scripts
# Simple rule
from openhab import rule, Registry
from openhab.triggers import GenericCronTrigger, ItemStateUpdateTrigger, ItemCommandTrigger, EphemerisCondition, when, onlyif
import scope
@rule()
@when("Time cron */5 * * * * ?")
def test1(module, input):
test1.logger.info("Rule 1 was triggered")
@rule()
@when("Item Item1 received command")
@when("Item Item1 received update")
@onlyif("Today is a holiday")
def test2(module, input):
Registry.getItem("Item2").sendCommand(scope.ON)
@rule(
class Test3:
self.logger.info("Rule 3 was triggered")
@rule(
triggers = [
ItemStateUpdateTrigger("Item1"),
conditions = [
EphemerisCondition("notholiday")
class Test4:
if Registry.getItem("Item2").postUpdateIfDifferent(scope.OFF):
self.logger.info("Item2 was updated")
# Query thing status info
from openhab import logger, Registry
info = Registry.getThing("zwave:serial_zstick:512").getStatusInfo()
logger.info(info.toString());
# Query historic item
from datetime import datetime
historicItem = Registry.getItem("Item1").getPersistence().persistedState( datetime.now().astimezone() )
logger.info( historicItem.getState().toString() );
historicItem = Registry.getItem("Item2").getPersistence("jdbc").persistedState( datetime.now().astimezone() )
# Using scope
Simple usage of jsr223 scope objects
from openhab import Registry
from scope import ON
Registry.getItem("Item1").sendCommand(ON)
# Logging
There are 3 ways of logging.
- using normal print statements. In this case they are redirected to the default openHAB logfile and marked with log level INFO or ERROR
import sys
print("log message")
print("error message", file=sys.stderr)
- using the logging module. Here you get a logging object, already initialized with the prefix "org.openhab.automation.pythonscripting"
from openhab import logging
logging.info("info message")
logging.error("error message")
- using the rule based logging module. Here you get a logging object, already initialized with the prefix "org.openhab.automation.pythonscripting.
class Test:
# Decorators
# decorator @rule
The decorator will register the decorated class as a rule. It will wrap and extend the class with the following functionalities
- Register the class or function as a rule
- If name is not provided, a fallback name in the form "{filename}.{function_or_classname}" is created
- Triggers can be added with argument "triggers", with a function called "buildTriggers" (only classes) or with an @when decorator
- Conditions can be added with argument "conditions", with a function called "buildConditions" (only classes) or with an @onlyif decorator
- The execute function is wrapped within a try / except to provide meaningful error logs
- A logger object (self.logger or {functionname}.logger) with the prefix "org.automation.pythonscripting.{filename}.{function_or_classname}" is available
- You can enable a profiler to analyze runtime with argument "profile=1"
- Every run is logging total runtime and trigger reasons
class Test:
2025-01-09 09:35:11.002 [INFO ] [tomation.pythonscripting.demo1.Test2] - Rule executed in 0.1 ms [Item: Item1]
2025-01-09 09:35:15.472 [INFO ] [tomation.pythonscripting.demo1.Test1] - Rule executed in 0.1 ms [Other: TimerEvent]
'execute' callback 'input' parameter
Depending on which trigger type is used, corresponding event objects (opens new window) are passed via the "input" parameter
The type of the event can also be queried via AbstractEvent.getTopic (opens new window)
# decorator @when
@when("Item Test_String_1 changed from 'old test string' to 'new test string'")
@when("Item gTest_Contact_Sensors changed")
@when("Member of gTest_Contact_Sensors changed from ON to OFF")
@when("Descendent of gTest_Contact_Sensors changed from OPEN to CLOSED")
@when("Item Test_Switch_2 received update ON")
@when("Member of gTest_Switches received update")
@when("Item Test_Switch_1 received command")
@when("Item Test_Switch_2 received command OFF")
@when("Thing hue:device:default:lamp1 received update ONLINE")
@when("Thing hue:device:default:lamp1 changed from ONLINE to OFFLINE")
@when("Channel hue:device:default:lamp1:color triggered START")
@when("System started")
@when("System reached start level 50")
@when("Time cron 55 55 5 * * ?")
@when("Time is midnight")
@when("Time is noon")
@when("Time is 10:50")
@when("Datetime is Test_Datetime_1")
@when("Datetime is Test_Datetime_2 time only")
@when("Item added")
@when("Item removed")
@when("Item updated")
@when("Thing added")
@when("Thing removed")
@when("Thing updated")
# decorator @onlyif
@onlyif("Item Test_Switch_2 equals ON")
@onlyif("It's not a holiday")
@onlyif("Tomorrow is not a holiday")
@onlyif("Today plus 1 is weekend")
@onlyif("Today minus 1 is weekday")
@onlyif("Today plus 3 is a weekend")
@onlyif("Today offset -3 is a weekend")
@onylyf("Today minus 3 is not a holiday")
@onlyif("Yesterday was in dayset")
@onlyif("Time 9:00 to 14:00")
# Modules
# module scope
The scope module encapsulates all default jsr223 objects/presents (opens new window) into a new object. You can use it like below
from scope import * # this makes all jsr223 objects available
print(ON)
from scope import ON, OFF # this imports specific jsr223 objects
print(ON)
import scope # this imports just the module
print(scope.ON)
You can also import additional jsr223 presents (opens new window) like
from scope import RuleSimple
from scope import RuleSupport
from scope import RuleFactories
from scope import ScriptAction
from scope import cache
from scope import osgi
Additionally you can import all Java classes from 'org.openhab' package like
from org.openhab.core import OpenHAB
print(str(OpenHAB.getVersion()))
# module openhab
| Class | Usage | Description |
| rule | @rule( name=None, description=None, tags=None, triggers=None, conditions=None, profile=None) | Rule decorator to wrap a custom class into a rule |
| logger | logger.info (opens new window), logger.warn ... | Logger object with prefix 'org.automation.pythonscripting.{filename}' |
| Registry | see Registry class | Static Registry class used to get items, things or channels |
| Timer | see Timer class | Static Timer class to create, start and stop timers |
| Set | see Set class | Set object |
# module openhab.actions
| Audio | see openHAB Audio API (opens new window) | |
| BusEvent | see openHAB BusEvent API (opens new window) | |
| Ephemeris | see openHAB Ephemeris API (opens new window) | |
| Exec | see openHAB Exec API (opens new window) | e.g. Exec.executeCommandLine(timedelta(seconds=1), "whoami") |
| HTTP | see openHAB HTTP API (opens new window) | |
| Log | see openHAB Log API (opens new window) | |
| Ping | see openHAB Ping API (opens new window) | |
| ScriptExecution | see openHAB ScriptExecution API (opens new window) | |
| Semantic | see openHAB Semantic API (opens new window) | |
| Things | see openHAB Things API (opens new window) | |
| Transformation | see openHAB Transformation API (opens new window) | |
| Voice | see openHAB Voice API (opens new window) | |
| NotificationAction | e.g. NotificationAction.sendNotification("[email protected]", "Window is open") |
# module openhab.triggers
| when | @when(term_as_string) | When trigger decorator to create a trigger by a term |
| onlyif | @onlyif(term_as_string) | Onlyif condition decorator to create a condition by a term |
| ChannelEventTrigger | ChannelEventTrigger(channel_uid, event=None, trigger_name=None) | |
| ItemStateUpdateTrigger | ItemStateUpdateTrigger(item_name, state=None, trigger_name=None) | |
| ItemStateChangeTrigger | ItemStateChangeTrigger(item_name, state=None, previous_state=None, trigger_name=None) | |
| ItemCommandTrigger | ItemCommandTrigger(item_name, command=None, trigger_name=None) | |
| GroupStateUpdateTrigger | GroupStateUpdateTrigger(group_name, state=None, trigger_name=None) | |
| GroupStateChangeTrigger | GroupStateChangeTrigger(group_name, state=None, previous_state=None, trigger_name=None) | |
| GroupCommandTrigger | GroupCommandTrigger(group_name, command=None, trigger_name=None) | |
| ThingStatusUpdateTrigger | ThingStatusUpdateTrigger(thing_uid, status=None, trigger_name=None) | |
| ThingStatusChangeTrigger | ThingStatusChangeTrigger(thing_uid, status=None, previous_status=None, trigger_name=None) | |
| SystemStartlevelTrigger | SystemStartlevelTrigger(startlevel, trigger_name=None) | for startlevel see openHAB StartLevelService API (opens new window) |
| GenericCronTrigger | GenericCronTrigger(cron_expression, trigger_name=None) | |
| TimeOfDayTrigger | TimeOfDayTrigger(time, trigger_name=None) | |
| DateTimeTrigger | DateTimeTrigger(cron_expression, trigger_name=None) | |
| PWMTrigger | PWMTrigger(cron_expression, trigger_name=None) | |
| GenericEventTrigger | GenericEventTrigger(event_source, event_types, event_topic="/", trigger_name=None) | |
| ItemEventTrigger | ItemEventTrigger(event_types, item_name=None, trigger_name=None) | |
| ThingEventTrigger | ThingEventTrigger(event_types, thing_uid=None, trigger_name=None) | |
| ItemStateCondition | ItemStateCondition(item_name, operator, state, condition_name=None) | |
| EphemerisCondition | EphemerisCondition(dayset, offset=0, condition_name=None) | |
| TimeOfDayCondition | TimeOfDayCondition(start_time, end_time, condition_name=None) | |
| IntervalCondition | IntervalCondition(min_interval, condition_name=None) |
# Classes
# class Registry
| Function | Usage | Return Value |
| getThing | getThing(uid) | Thing |
| getChannel | getChannel(uid) | Channel |
| getItemMetadata | getItemMetadata(item_or_item_name, namespace) | openHAB Metadata (opens new window) |
| setItemMetadata | setItemMetadata(item_or_item_name, namespace, value, configuration=None) | openHAB Metadata (opens new window) |
| removeItemMetadata | removeItemMetadata(item_or_item_name, namespace = None) | openHAB Metadata (opens new window) |
| getItemState | getItemState(item_name, default = None) | openHAB State (opens new window) |
| getItem | getItem(item_name) | Item or GroupItem |
| resolveItem | resolveItem(item_or_item_name) | Item or GroupItem |
| addItem | addItem(item_config) | Item or GroupItem |
| safeItemName | safeItemName(item_name) |
# class Item
Item is a wrapper around openHAB Item (opens new window) with additional functionality.
| postUpdate | postUpdate(state) | |
| postUpdateIfDifferent | postUpdateIfDifferent(state) | |
| sendCommand | sendCommand(command) | |
| sendCommandIfDifferent | sendCommandIfDifferent(command) | |
| getPersistence | getPersistence(service_id = None) | ItemPersistence |
| getSemantic | getSemantic() | ItemSemantic |
| <...> | see openHAB Item API (opens new window) |
# class GroupItem
GroupItem is an extended Item which wraps results from getAllMembers & getMembers into Items
# class ItemPersistence
ItemPersistence is a wrapper around openHAB PersistenceExtensions (opens new window). The parameters 'item' and 'serviceId', as part of the Wrapped Java API, are not needed, because they are inserted automatically.
| Function | Usage | Description |
| getStableMinMaxState | getStableMinMaxState(time_slot, end_time = None) | Average calculation which takes into account the values depending on their duration |
| getStableState | getStableState(time_slot, end_time = None) | Average calculation which takes into account the values depending on their duration |
| <...> | see openHAB PersistenceExtensions API (opens new window) |
# class ItemSemantic
ItemSemantic is a wrapper around openHAB Semantics (opens new window). The parameters 'item', as part of the Wrapped Java API, is not needed because it is inserted automatically.
| Function | Usage |
| <...> | see openHAB Semantics API (opens new window) |
# class Thing
Thing is a wrapper around openHAB Thing (opens new window).
| Function | Usage |
| <...> | see openHAB Thing API (opens new window) |
# class Channel
Channel is a wrapper around openHAB Channel (opens new window).
| Function | Usage |
| <...> | see openHAB Channel API (opens new window) |
# class Timer
| createTimeout | createTimeout(duration, callback, args=[], kwargs={}, old_timer = None, max_count = 0 ) | Create a timer that will run callback with arguments args and keyword arguments kwargs, after duration seconds have passed. If old_timer from e.g previous call is provided, it will be stopped if not already triggered. If max_count together with old_timer is provided, then 'max_count' times the old timer will be stopped and recreated, before the callback will be triggered immediately |
# class Set
This is a helper class which makes it possible to use a Python 'set' as an argument for Java class method calls
# Others
# Threading
Thread or timer objects which was started by itself should be registered in the lifecycleTracker to be cleaned during script unload.
import scope
import threading
class Timer(theading.Timer):
def __init__(self, duration, callback):
super().__init__(duration, callback)
def shutdown(self):
if not self.is_alive():
return
self.cancel()
self.join()
def test():
print("timer triggered")
job = Timer(60, test)
job.start()
scope.lifecycleTracker.addDisposeHook(job.shutdown)
Timer objects created via openhab.Timer.createTimeout, however, automatically register in the disposeHook and are cleaned on script unload.
from openhab import Timer
def test():
Timer.createTimeout(60, test)
Below is a complex example of 2 sensor values that are expected to be transmitted in a certain time window (e.g. one after the other).
After the first state change, the timer wait 5 seconds, before it updates the final target value. If the second value arrives before this time frame, the final target value is updated immediately.
from openhab.triggers import ItemStateChangeTrigger
@rule(
triggers = [
ItemStateChangeTrigger("Room_Temperature_Value"),
ItemStateChangeTrigger("Room_Humidity_Value")
class UpdateInfo:
def __init__(self):
self.update_timer = None
def updateInfoMessage(self):
msg = "{}{} °C, {} %".format(Registry.getItemState("Room_Temperature_Value").format("%.1f"), Registry.getItemState("Room_Temperature_Value").format("%.0f"))
Registry.getItem("Room_Info").postUpdate(msg)
self.update_timer = Timer.createTimeout(5, self.updateInfoMessage, old_timer = self.update_timer, max_count=2 )
# Python <=> Java conversion
In addition to standard value type mappings (opens new window), the following type mappings are available.
| Python class | Java class |
| datetime with timezone | ZonedDateTime |
| datetime without timezone | Instant |
| timedelta | Duration |
| list | Set |
| Item | Item |
# Typical log errors
# Exception during helper lib initialisation
There were problems during the deployment of the helper libs. A typical error is an insufficient permission. The folder "conf/automation/python/" must be writeable by openHAB.
# Failed to inject import wrapper
The reading the Python source file "conf/automation/python/lib/openhab/wrapper.py" failed.
This could either a permission/owner problem or a problem during deployment of the helper libs. You should check that this file exists and it is readable by openHAB. You should also check your logs for a message related to the helper lib deployment by just grep for "helper lib".
# Limitations
- GraalPy can't handle arguments in constructors of Java objects. Means you can't instantiate a Java object in Python with a parameter. https://github.com/oracle/graalpython/issues/367 (opens new window)
